wilharper2000
- Joined
- Sep 15, 2006
- Location
- UK
- TDI
- Golf 2 GTD 80HP (SB), 2001 Audi A6 115PD TDI (AJM), Polo 1.4TDI (AMF)
Hi guys
Just rebuilding my 1.6td properly and have measured the piston protrusions, which are as follows:
Cyl. 1 - 0.98mm
Cyl. 2 - 1.02mm
Cyl. 3 - 0.98mm
Cyl. 4 - 0.98mm
This is right on the limit of a 3 notch gasket, i think due to the fact the block has been faced and new small end bushings have been fitted. I have removed and checked Cyl.2 assembly and reinstalled and got the same measurement.
I carried out a good analysis of my measuring equipment and I think I can be confident to 0.02mm, therefore my Cyl.2 may be slightly over.
What im trying to work out is if this may cause an issue with valve piston contact. Initially I was going to have the conrod reworked but then I remembered there is actually quite a lot of tolerance in the cylinder head, specifically valve recess depth (0.5mm - 1.50mm) for this engine. Mine are all 0.95mm
Can anyone tell me if i'm right to think that this allowance gives me a bit of room on piston protrusion? I've attached a little drawing to primarily help me understand this but it might help explain what im getting at. Ignore the cam position! Thanks, Will
Cyl. 1 - 0.98mm
Cyl. 2 - 1.02mm
Cyl. 3 - 0.98mm
Cyl. 4 - 0.98mm
