hskrdu
Hi all! (Her) 2015 GSW (6M) has had its first issue. Routine drive on the highway, low coolant warning 20 minutes after departure from home.
(Days later, inspecting for source of leak. Dripping from yellow box on passenger side, high up, next to radiator).
Pulled over: Coolant bottle was low, engine temp was normal, so I added de-ionized water (did not have G13 with me). Steam was coming from bottom of engine, but the roads were not dry and I could not find the leak or determine the source of the steam (but I could smell the coolant). Engine oil on dipstick looked normal.
Later, tasks complete, no further low coolant warning until almost home- engine temp still normal. Coolant bottle was "empty" and later re-filled properly. Engine oil on dipstick looked normal.
A few days later, with a dry engine bay, I started the engine and inspected for leaks. After about five minutes of idling, with the engine temp gauge just starting to rise, I found coolant dripping from high up, next to the radiator, on the passenger side. After poking around and trying to trace it, coolant seemed to be coming from a small yellow plastic box, which sits to the side of the radiator, right next to the headlight housing, and is just a few inches below the highest point of the radiator. I kept looking for the "actual" source of the leak, as I didn't recognize this item as being part of the cooling system, but could not find any leaks above that yellow box. The coolant quickly pooled on the belly pan, and drips eventually scattered a bit, probably due to the accessory belt.
Questions:
Is it possible the this yellow box is the source of the leak, or did I miss the origin?
I can't find that yellow part in the self study guide or the online manual- anyone know what it is?
If it is not the source of the leak, but I can see the coolant collecting and dripping from the yellow box, are there any suggestions for likely sources?
(Click on picture for full size). (Passenger side of engine bay, looking towards the radiator. Highest point of coolant dripping appears to be the yellow box that sits between the rad hose and headlight wiring).
(Click on picture for full size). (Close-up of yellow box, orientation is same as photo above).
Thanks all!
Questions:
Thanks all!
