Psilovybin
TLDR; when changing the oil cooler on the CKRA, change the crankshaft sensor at the same time.
I had changed out the oil cooler on my sister's car back in August. Everything went well. Had a bit of trouble with the intercooler being in the way and getting it out of the way. Once that was done, oil cooler change was rather easy. That being said, fast forward to end of September and the car isn't starting on demand. Pulling the codes, getting engine speed sensor errors. After doing more diags and verifying cam sensor is ok (changed timing belt too in August), I've found the crank sensor is throwing erroneous data causing the engine to not start on demand but when it does start, it runs fine until you shut it off. In hindsight, I should've changed the crankshaft sensor while I was changing the oil cooler. Would've been easier then, now I have to take the intercooler back off.
