5150
How's the progress?
Any new developments?
Looks great.
Looks great.
Thanks. I should have more to post in about a week or so as I ordered the rest of the tubing and parts for the exhaust and the bends to make the charge pipes. I still need to get the silicone connectors though so the exhaust will probably get done first.5150 said:Any new developments?
Looks great.
Man you aren't kidding...lol. My God whoever had that car was one sick individual...vwmikel said:
And of course in 6th gear.
(yes, I know that console is disgusting.... I have another sitting around which I may use as I'm sure it's cleaner than that one)
They should have made those bolt holes blind, not thru holes.G60ING said:yeah the 42 designs map sensor rocks. use some gasket maker sealant on the threads of the bolts on your final assembly or you will have a small leak. Looks good.
yeah its not too bad. I pressure checked my IC pipes to make certain they would hold at least 35psivwmikel said:I think it was probably cheaper and easier to do it that way. Some anti-seize would probably do the trick.
Total cost so far? I'm something like $9-10k into it right now. It's far from an economical swap, that's for sure. I'm sure I could have kept the costs lower but there are just some things I wanted out of this car. It's not like me to drive a car at (or anywhere near) stock height or without replacing every bushing and bearing....nor did I want stock wheels or a crappy stereo.storx said:keep up the good work man.. its a killer setup.. wish i could do something like this.. what you go into this?
Wow, that really isnt a whole lot.. haha....im right now debating on a project that i want to do next, Im wanting an pickup truck so im debating an 4x4 Toyota Tacoma EXT with an TDI engine... possably an PD150 motor but budget will control that. I already have the truck, It has an blown engine but good manual tranny and transfer case.vwmikel said:Total cost so far? I'm something like $9-10k into it right now. It's far from an economical swap, that's for sure. I'm sure I could have kept the costs lower but there are just some things I wanted out of this car. It's not like me to drive a car at (or anywhere near) stock height or without replacing every bushing and bearing....nor did I want stock wheels or a crappy stereo.
