Usually the rod bolts shear on the bxe due to cheap, low quality oil but it’s often the camshaft that go 1st ! As a minimum upgrade the rod bolts to ARL spec ones, they are 12.9 tensile grade vs 10.9 on the lower power engines. Also I recommend sputter bearings for the rod bolts, they are going trough immense stress on modified engines and you want piece of mind really ! I would also stress going to a larger turbo as they are more linear in torque delivery, as I mentioned above I have fixed a few of them 105 Bhp engine with bent rods due to small, punchy turbos that boost too much, too quick ! Also fit an EGT gauge to keep an eye on exhaust temps, small turbos tend to boost creep on re-maps with poor vnt control !
