PD Underboost limp mode VCDS diagnostics tips n' tricks
TurboABA
Kitchener, ON
RIP-2010 Jetta 6spd 2014 Touareg Execline
You're not providing screenshots of errors or full scan codes.... I'm not really sure what you're doing and I'm starting to think you don't know either.
If you blew out codes without fixing stuff and are now unable to drive it to replicate the conditions to trigger them again, having the diagnostic tool won't help much since there's no issue to diagnose.
TurboABA
Kitchener, ON
Any thoughts about why I wasn't able to call up the gateway screen?
I forgot that you're scanning a dinosaur.... CAN gateway was introduced in '04, so prior to that, they were using K-line diagnostics, so it sounds like you're SOL on that feature.
Are your software and dongle updated to the latest firmware and version?
Mozambiquer
Versailles Missouri
As turbo aba mentioned, this car is k-line, not can, so there isn't a can gateway.
Next time it acts up, hook it up and snap a few photos of the codes that are logged, both on the ecm and the TCM.
Zeitgeist
Cascadia
'04 Variant and Vanagon mTDI
Dear gawd, by now I thought it was obvious that I'm a babe in the woods wrt digital stuff. VCDS is a suite of tools I don't understand nor do I know anything beyond the rudimentary reading of codes and making them disappear. This kind of wack-a-mole symptom hide and seek is pretty maddening. Oh, and also there's no manual for these B5.5 TDIs, so I'm truly blind.
This car had a cheesy aftermarket HU in it when I bought it, but I've since pulled it and the wires are just dangling. There's some kind of adapter in there, but the steering controls didn't function. Yes, there's a recurring code for the radio, but that was there even when the HU was connected. The horn won't function from the steering wheel, but when I ran an output test last night, I got both the security and main horns to beep. I was also able to pretty much determine that the mirror switch in the door is disconnected or has totally failed, but I assume that's not relevant.
Oh one other thing, there was a gear selector code in the ABS module. I did try to save the codes before I deleted them, but I don't know how to retrieve them.
Zeitgeist
Cascadia
Monday,29,November,2021,19:05:38:28771
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64) HEX-NET2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WVWVE63B24E282139 License Plate:
Mileage: 297410km-184802mi Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWVE63B24E282139 Mileage: 297410km-184802miles
Address 01: Engine Labels: 038-906-016-BHW.lbl
Part No SW: 038 997 016 T HW: 028 101 143 3
Component: R4 2,0L EDC G000AG 0314
Revision: 12345678 Serial number: VWZ7Z0D9238480
Coding: 0150034
Shop #: WSC 23344 444 11345
VCID: 2F307ABE4B0A4A430EB-5160
VINID: 9E69E65460D208454220204324B6C0DA4E
3 Faults Found:
16791 - EGR Sensor 2
P0407 - 000 - Signal too Low
Freeze Frame:
RPM: 0 /min
Torque: 236.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -1.3 %
Mass Air / Rev.: 850.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Bin. Bits: 00000000
19558 - Motor for Intake Manifold Flap (V157)
P3102 - 000 - No Signal
Freeze Frame:
RPM: 0 /min
Torque: 236.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00001000
Torque: 146.0 Nm
Torque: 108.0 Nm
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 0 /min
Torque: 236.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00001000
Torque: 146.0 Nm
Torque: 108.0 Nm
Readiness: 1 3 0 0 1
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 3B0 927 156 AP
Component: AG5 01V 2.0lPD USA 1213
Coding: 0001104
Shop #: WSC 05311 000 00000
VCID: 74BAB5D2E2AC299BB39-5160
No fault code found.
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04257
Shop #: WSC 05311
VCID: 251C98961CF60013F47-51F2
1 Fault Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0003
Coding: 12345
Shop #: WSC 05311
VCID: 241A859217CCF91BE39-513C
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 05311
VCID: 2F307ABE4E0A4A430EB-5160
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 929 C
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 15235
Shop #: WSC 09146
VCID: 2700929E66FA1203C6B-513C
WVWVE63B24E282139 VWZ7Z0D9238480
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05311
VCID: 70B2B9C293B415BB571-513C
1 Fault Found:
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 80 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 05311
VCID: 372042DEB65A828356B-4B1E
Subsystem 1 - Part No: 1C1959801
Component: 80 Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802
Component: 80 Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811
Component: 80 Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812
Component: 80 Tõrsteuer.HR KLO 0202
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
54-00 - Incorrectly Equipped
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
End----(Elapsed Time: 04:41, VBatt start/end: 12.0V/12.1V. VIgn 11.8V)-----
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 46: DTCs cleared
Mozambiquer
Versailles Missouri
www.Ross-Tech.com
Coding: 0150034
3 Faults Found:
Freeze Frame:
RPM: 0 /min
Torque: 236.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -1.3 %
Bin. Bits: 00000000
Freeze Frame:
RPM: 0 /min
Torque: 236.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00001000
Torque: 146.0 Nm
Torque: 108.0 Nm
Freeze Frame:
RPM: 0 /min
Torque: 236.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00001000
Torque: 146.0 Nm
Torque: 108.0 Nm
Coding: 0001104
Coding: 04257
Shop #: WSC 05311
1 Fault Found:
Coding: 12345
Shop #: WSC 05311
Coding: 00118
Shop #: WSC 05311
Coding: 15235
Shop #: WSC 09146
1 Fault Found:
01304 - Radio
Coding: 00006
Shop #: WSC 05311
1 Fault Found:
01304 - Radio
Coding: 00258
Shop #: WSC 05311
2 Faults Found:
TurboABA
Kitchener, ON
I'd ignore that for now.... it basically just store an ECU code to alert you that you should check your TCM for codes.....
If you notice, all his codes were stored when he wasn't running\driving.
Looks like he's got some wiring issues or a failed shudder valve (or at least one that's acting up)
Here's a few more things to squint at when pretending to be Fry
Zeitgeist
Cascadia
The EGR and anti-shudder valve are removed from the intake for "testing" purposes. Those codes keep popping up and have done so for a couple months. Other than the Emissions Workshop alarm, there were no changes in engine performance after the items were removed, except somewhere along the way the engine went from nearly always going into limp mode, to only occasionally; this despite me having absolutely nothing different to the engine.
These trans slipping problems just showed up recently. Why would a gear selection recognition code show up in an ABS module? I don't understand how a transmission can behave so badly without throwing a TCM code.
Zeitgeist
Cascadia
I just got back from a test drive and it ran and shifted perfectly, in fact the best I've experienced since buying it back in June. Other than all those output tests last night, the only other thing I did was remove the stereo adapter, as per that link T-ABA posted earlier.
When the trans acts up again, I promise I won't clear the codes prior to doing a deep dive with VCDS.
TurboABA
Kitchener, ON
Never ever clear codes without saving first. Always run autoscan and save before anything else. When you have an issue, troubleshoot.... Look at measuring blocks, do output tests, log sensors/values and come up with theories. Based on that, unplug suspect sensors if possible to validate your theory before throwing parts at the problem.
At least that's how I use the tool.
TurboABA
Kitchener, ON
Why would a gear selection recognition code show up in an ABS module? .
Probably because it uses thw ABS wheel speed sensor and compares it to the trans output shaft or something... If the varience is too great for the available gear ratios and rpm, it can only report that you are using an unknown gear to go X fast at Y rpm.
Zeitgeist
Cascadia
I'm wondering if a slipping TC would throw a monkey wrench into the mix because the expected engine RPMs won't match the gear ratio and axle speed. If I hadn't flushed those codes, we'd probably know the answer to that question right now.
Thanks for all the hand holding and hints. I'm learnin' stuff despite my best efforts to the contrary.
TurboABA
Kitchener, ON
I sure that if you want to be a trail blazer, you can spend some time to search for a SSP that explains how your slushbox works.... that the way most of us learn about all these systems so that we can at least have an iota of a clue as to the crap we poke around at. ;)
