SUNRG
- Joined
- Oct 19, 2003
- Location
- Roanoke, VA
- TDI
- None currently. Previously owned 04 Golf TDI & 05 Passat GLS Wagon TDI
PD Oil Information & Analysis
ELF - Excellium DID 505.01 5k UOA (Used Oil Analysis)
this is from my wife's Jetta. i was concerned that this UOA would have relatively high wear metals because i ran it hard (extended driving at 90-110mph during a road trip) but it came up with the lowest PD wear rates to date (Fe of 3.15ppm / 1000 miles). with nearly 35k on the ODO, this PD-TDI is further along in the break-in process than nearly all of the other PD UOAs - so despite the hard driving - it's lower wear metals are to be expected. that said, kudos to Elf Excellium DID for being the first PD oil to shatter the "Fe 4 ppm / 1000 mile wear rate barrier". i'm sure as more PDs approach 40 and 50k, Fe wear rates of 2-4ppm / 1000 miles will become more common.
TBN is <u>very strong</u> at 9.12 (down less than one point from a VOA of 10.20). nitration and oxidation are both very low (good) and viscosity is in grade at 12.67. this is the first UOA i've done on our Jetta, so it will serve as the benchmark against which future UOAs in this vehicle will be judged.
Fuel: ~2200 miles winter D2 with no additives, ~2800 miles B60
