SUNRG
- Joined
- Oct 19, 2003
- Location
- Roanoke, VA
- TDI
- None currently. Previously owned 04 Golf TDI & 05 Passat GLS Wagon TDI
What are PD oils?
PD = Pumpe Duse or the Unit Injector System found on 2004 model year and later TDIs in North America (2000 model year and later in the EU). PD Oils are oils that have been extensively tested by VW in Wolfsburg and approved for use in PD-TDI engines.
[Note: The owner's manual in many if not all 2004, 2005 & 2006 Golf TDIs (sold in the US) incorrectly specifies 505.00 oil. The engine depicted in the owner's manual is also incorrect - the 1.9L/90hp TDI is pictured, but 2004-2006 Golfs have 1.9L/100hp PD-TDI engines. TSB: page 1, page 2]
The three current VWAG PD-TDI approved specifications are:
[click on the specification number below for the most current list of all oils certified by VW to meet that specification]
Where can I get PD Oils?
Currently, from VW and Audi dealerships and some shops selling Motul, Elf, Pentosin, Quaker State or Lubro-Moly products. Many shops that carry products made by these manufacturers will not stock PD Oils - but may have the ability to special order them for you. The great news is that top-shelf PD Oils are never more than a few mouse clicks away. See the bottom of this post for a partial list of PD Oil Sources.
What's PD Oil Analysis?
Simply put, used oil analysis is where you send a small used oil sample to a lab, the lab analyzes many different factors that determine oil quality, sends you back a report, and by comparing your report to others posted here you can determine a lot about the internal condition of your PD-TDI engine.
How do I change my oil?
There are two common ways of changing the oil in a TDI: from the top using an oil extractor [VIDEO], or via the traditional oil drain method [PDF].
What oil filter should I use?
Using OEM quality oil filters is recommended. Always change the oil and the oil filter together. Never change the filter without changing the oil, and never change the oil without changing the filter. The OEM oil filters used in TDIs since 2000 are designed for up to 31,000 miles of use.
OEM filters are not expensive when purchased directly from the dealer, and are even less expensive when purchased from any number of online TDI parts suppliers.
How often should I change my oil?
VW / Owner's Manual Recommendation = 5k, 10k, 20k, 30k and every 10k miles thereafter. [Note: only the first two OCIs are 5k intervals.] Rest assured, the VW recommended oil change intervals are conservative - i.e. there is no benefit to changing your oil more often than recommended in stock TDIs [Perfomance modified TDIs may benefit from more frequent OCIs, and should use lab oil analysis to determine the vehicle's optimal OCI]. If you're concerned because your oil looks "dirty" (black) immediately after an oil change please click here.
How do I use an Oil Sampling Pump?
[Note: an oil sampling pump is needed for intermediate oil analyses (extracting a sample without changing your oil) and for extracting an uncontaminated sample when changing oil via the topside method. If changing oil via the traditional drain method, you can simply catch a sample of the oil as it is draining.]
If you have had your PD oil analyzed please post your results to this thread so we can include them in this study/spreadsheet. Thanks!
Data Sheets for oils currently being tested:
The image below is just sample of some of the VOA and UOA data spreadsheet that is not updated.
Please click the above link to view the entire updated spreadsheet.
Here's a "runway" of all the VOA samples, in case anyone wants to select their oil on looks alone
For comparison to UOAs from earlier TDI engines, click here to view TDI UOAs from BITOG
Castrol 505.01
VW Dealers
www.1stvwparts.com, VW Part# G052167A2
www.worldimpex.com, VW Part# G052167A2
www.ecstuning.com, 800.924.5172
ELF 505.01, 506.01 & 507.00
Click here for a listing of NA Retailers and Distributers
www.tdiparts.com - 914.481.6136, sales@tdiparts.com **506.01 & 507.00**
Sabre-Chem, Inc. - 918.587.1555, scott@sabrechem.com
Mountain Products, Co. - 303.770.5767, chriswchap@aol.com
www.ElfUSA.com
http://turbofrogperformance.com - froggy@turbofrogperformance.com **507.00**
Motul 505.01 & 506.01
Click here for a listing of US Retailers and Distributers www.worldimpex.com - 800.736.3550
www.bobbyarchermotorsports.com - 817.877.1772
www.singhmotorwerks.com
www.ltbmotorsports.com
www.northamericanlubricants.com - 800.430.6252
MotorSPOT - 760.731.8303
German Parts & Restoration - 800-321-5432 **506.01**
PentosynthTS 505.01
- 505.01 - semi-synthetic, fixed drain interval - 10k OCIs, Aug05 50501 TSB
- 506.01 - full-synthetic, fuel economy optimizing, extended service interval - up to 31k or 2 year OCIs
- 507.00 - full-synthetic, low SAPS / diesel particulate filter compatible, fuel economy improving, extended service interval
- Oil Analysis 101 by TooSlick
- Oil Analysis Information from Oil Analyzers, Inc.
- What is Oil Analysis? from www.bobistheoilguy.com
- What is Oil Analysis? from www.blackstone-labs.com
Elf Solaris LLX 5w-30 507.00
Elf Evolution CRV 0w-30 506.01
Elf Exellium DID 5w-40 505.01
Motul Specific 5w-40 505.01
Motul Specific 0w-30 506.01
Castrol TXT 5w-40 505.01 [unable to find data sheet]
MSDS - PENTOSYNTH Synthetic OIL 5W-40 (TS) SJ/CF
VOA Comparison (LAP, TBN, Vis.) of all 505.01, 506.01 & 505.00 (M1-T&SUV)
----------------------------------------Elf Evolution CRV 0w-30 506.01
Oil Analysis Kit Sources:
- Oil Analyzers - [http://www.oaitesting.com/]. With Amsoil Preferred Customer membership, their very thorough testing - including TBN is only $15.20. AndyH is offering the OA kits near preferred pricing for TDIclub members that are not Amsoil members [click here for pricing and details]. Here's Andy's contact information:
Andrew Hecker
Independent AMSOIL Account Direct
9406 Vallecito Pass
San Antonio, TX 78250
www.zamslube.com
1-877-271-7646
210 392-3631
210 521-7635 fax
ahecker@zamslube.com
9406 Vallecito Pass
www.zamslube.com
1-877-271-7646
210 392-3631
210 521-7635 fax
- Oil Guard - http://www.oilguard.com
- Blackstone - http://www.blackstone-labs.com/
- CAT SOS Oil Analysis - http://www.cat.com/cda/layout?m=40740&x=7
- AV Lubricants Inc. - http://store.avlube.com/oilandfuanki.html
Articles and information regarding VW Oil Specifications
- New VAG 504.00 & 507.00 Standards
- Scott Ellis, Southwest Research Institute 505.01 letter + VWaG 505.01 Document
- ELF VW Oil Spec Slides & ELF SOLARIS LLX 504 / 507
- VW Oil Spec Article & 506.01 Information
- 505.01 info, Motul 505.01 slildes, Motul 505.01 vs CI-4, Scott Ellis SRI letter
- VWAG 505.01 Approved Oils (Oct.03)
- Motul & Castrol 505.01 / 506.01 Information and Discussions
- 505.00 vs CI-4 comparison that becomes an API vs ACEA discussion +
- 100,000 kilometer Oil Change Intervals
- the BLACK oil experiment
- initial Elf Evolution CRV 506.01 UOA and discussions
- Elf Solaris LLX 507.00 information & slides
PD Oil Sources
Castrol 505.01
VW Dealers
www.ElfUSA.com
PentosynthTS 505.01
