PD Injectors adjustment screw setting
aRd
UK
MK4 Golf TDI PD
MK4 Golf PD ARL engine code,
in the bentley manual it say
screw adjusting screw into rocker arm until a notable resistance can be felt (unit injector positioned at stop).
– Turn adjuster screw 225° back off stop.
– Hold adjustment screw in this position and tighten the lock nut to 30 Nm.
in Elsawin
– Turn adjuster screw 180° back off stop.
I've set my injectors based on the bentley manual 225° back off, realised now it should have been set to 180° back off, does 1/8 turn make much difference?
what are you thoughts on this.
dieselpower04
Outside Tampa, FL
2004 Golf GLS TDI (sold)
I think the new number is 180*. That's what we set my injectors to when installed the ARL units in my BEW.
You should be able to change it back pretty easily no?
Franko6
Sw Missouri
Jetta, 99, Silver`
It is 180 degrees. VW changed the number for all PD's. The difference?... It's easier to remember.
m1ketdi
Leam
Leon BKD
45degrees on what i think is a fine pitch thread is 0.125mm. In PD injector terms thats going to change pressure build up relative to crank posistion a small amount, probably not noticable to all but the most anal though.
aRd
UK
MK4 Golf TDI PD
Cheers all
Bentley manual is based on the factory manual (ElsaWin), particular version we use is a little out of date.
When I (and BoraChris) get a chance we'll adjust them to 180.
borachris
UK-Billingham
Bora ASZ 130PD, Corrado 150PD in production
Damn sure I won't Ray, not wasting time messing about with that, pointless IMO!
From now on I'll use 180 instead of 225, purely as it's easier to remember as said above!
ryanp
Barnsley, South Yorkshire, UK
Arosa CR - 550hp - 9.7 @ 150mph 1/4 Mile, Citigo 4x4 CR TDi - 340hp, Caddy 2.0 CR 4x4 TDI - 300+hp, Golf Mk2 Van 1.9 TDI - was 290hp, Mk5 Ibiza 2.0 FR TDi - 270hp, BMW 135d - 360hp, BMW 330d - 335hp, BMW 335d - 380hp + a few more ........
haha, you two are like an old married couple! lol
Did Lee show you the turbo? the lever i took out was a proper bodge!
borachris
UK-Billingham
I do feel like divorcing him sometimes like Ry :p
Yeah had a look today, good job mate!
Cheers for those bits mate, arrived yesterday :)
Tuneme
Europe
Ibiza Cupra Tdi
Quick one on this topic regarding this settings with performance cam, is 180" normal or should it be backed off more?
A5INKY
Louisville, KY
2006 Jetta TDI, 2002 Eurovan Westphalia VR6
180 deg works fine for even performance cams, no reason to change it.
IIRC the 225° has the benefit that the engine is above 3000 more alive than with 180°.
This is the thread i remember:
http://community.dieselschrauber.de/viewtopic.php?t=5408&highlight=pde+180
Cheers
Feinstaub
The change in power characteristic cited in your link has to do with cam to crank timing, not pump injector setting.
The pump injector rocker setting is to calibrate full pump travel minus a consistent distance to prevent mechanically bottoming them out. What is important is not so much 180 vs. 225 degrees backed off, but that they are consistent from injector to injector.
