A5INKY
Car is a customer's '05 Passat with a BHW PD engine. Customer bought this car after it had changed hands several times with 3-4 different shops not being able to fix it. No surprise, tons of work had been done and most of it of very poor quality. After a general detooefing of substandard previous work, issue still plagues it, a cylinder #3 misfire. This fault shows up in measuring block 23 only intermittently under load while driving and values for that injector only go sky high when the fault is occurring.
To try and solve it a bunch of work has been done:
So, I have done a process of elimination and I think am down to a failing injector #3 driver in the ECU itself. Only thing I can think to do before swapping ECUs is swap #3 and #4 injectors to make sure that (if by some astronomically unlikely probability) the bad injector has gone undetected and keeps ending up in the same #3 hole.
Anyone seen a failed ECU in one of these yet? Anyone see some troubleshooting step I am missing?
Thanks in advance
- Found loose bolts under the VC including injector hold-down bolts after other shop put in a Colt cam, so pulled the head, new correct gasket and checked what can be checked. Reassembled properly with proper new parts.
- While head was off, found that previous shop had replaced #3 injector with new of different P/N. So found old injector in box of provided parts and sent all 5 to Drivbiwire for new nozzles and full rebuild. He used old #3, said it was good now.
- Swapped head injector harness loom with known good used one while head was off just because.
- Had ECU tuned to Stage 1 from TD Tuning with EGR corrective "stuff" done
- Checked wiring harness back to 60 pin plug on ECU with aggressive wiggle test, not open
Thanks in advance
