estwing
I'm looking for a source for the four fuel lines that attach at the fuel filter. I'd prefer to stick with the molded hoses but cannot find a non-dealer source. The usual vendors don't have them. Any suggestions?
Can you read the part numbers off of them (should be stamped on the hoses). If so, you can order online from here:I'm looking for a source for the four fuel lines that attach at the fuel filter. I'd prefer to stick with the molded hoses but cannot find a non-dealer source. The usual vendors don't have them. Any suggestions?
Why are you replacing all the fuel lines?found these: but i need the others, before the fuel filter
http://www.idparts.com/catalog/product_info.php?products_id=2423
They will fit better and cost about 100x more than needed, but you can use the Gates Barricade hose. ~$30 vs. close to $200. $30 wins every time.Hello fellow members. When I had my ALH Golf I had a TDI guru replace the stock OEM, twisty and kinky fuel lines with straight VITON. These are the lines from firewall to filter and filter to head. They worked normally and I felt a bit better about running biodiesel and longevity.
I have a mechanic doing some minor stuff on the daughter's 2005 BEW. He's not a trusted TDI mechanic but has replaced cam position sensor, thermostat, etc.
He's concerned about using fuel line that doesn't have those bends and twists. Is there anything, general or specific, about the BEW lines to warrant his concerns?
Thanks in advance.
Those are the one$ I'm trying to avoid.ID Parts has these 2-
https://www.idparts.com/fuel-delivery-pipe-oem-a4-bew-p-2011.html
https://www.idparts.com/fuel-line-from-filter-to-head-a4-bew-p-2423.html
They just need to fit, proper hose, proper connects.
I need the correct inside and outside diameter.All you need is the right hose with the correct ends.
