I wouldnt worry about these numbers. When I first got chipped I got on it a little too hard below 2000 rpm and saw spikes to over 30psi. This prompted me to get a boostvalve installed ASAP! My turbo now spikes to about 25 or 26 and settles to around 20-21 and then climbes up to 24 at high rpms in fourth and fifth (WOT over 90mph). It also tends to act funny in third sometimes. It almost seems like the turbo and the N75 valve are fighting eachother as the boost will float back and fourth between 19 and 22psi most of the way through third gear. There is at least one member on this forum who is running 23psi continuous on the stock turbo.
I did a long hard run up to over 100mph a couple weeks ago and the car ran at 25psi for about 5 seconds before going into limp mode at roughly 120mph(it started climbing from around 20 when I hit 100 in 5th). I DO NOT recommend doing this as it is probably not good for the turbo at all. This being said, my car spikes to 25-26 and runs 20psi all day long without any complaint. The member who is running 23 psi continuous on his car has been doing so for the past 50k mi without any problems.(I believe Deathengine is the person I am speaking of....do a search and you should find his posts where he talks about it)
I have yet to read about one of these turbos failing. Someone correct me if I am wrong, but as far as I know these turbos have taken everything we have thrown at them so far without a complaint.
I would love to hear if there is anyone who is running higher than 23 continuous, and if so how long has it been this way. It seems that these turbos are quite tough and can take alot of abuse without breaking.
I do have a question for those of you who understand the turbo better than I do. The stock boost pressure for this engine is 16psi. I now have RC2 and am running 20psi. But when accelerating at about 1/3 to 1/2 throttle, when the turbo reaches 16psi I hear something open up and vent air. In lighter load conditions (1/2 throttle or less) the boost will actually back off to about 13psi without moving the gas pedal any. Is this the N75 valve venting air in an attempt to control the boost? If so, is there any way to adjust this?
Thanks,
Walter
