I've been running a modded 1Z with a 68pin ECU in my Toyota truck for a few years. (Mods in sig)
Anyway, it recently bit the dust, triggering my "must be time to upgrade."
I'm going to replace it with a PD, controlled with an EDC15P+ ECU. I have a few questions to start, regarding the control stuff.
I purchased the Bentley manuals for the A4, which covers the PD. I also have the older A3 manual for the 1Z.
The Bentley wiring diagram is a bit confusing, as I'm trying to cross-reference the pin numbers of the ECU to the one sitting in front of me.
The ECU is referred to as "J248" and the diagram starts on page 81/4
There are two connectors, and the Bentley manual refers to pins as "T94/XX" and "T60/XX" My confusion comes from the fact that there are no 94pin or 60pin connectors on the ECU. For example, a common pinout diagram is here:
http://forums.tdiclub.com/showthread.php?t=308247
Does anyone have any suggestions for clearing this up?
Also, there are some new inputs and devices to control. - Can these be deleted, like the EGR in the 1Z?
- N79 PCV heating
- V157 intake flap motor
- N345 EGR cooler switch over valve
- N156 intake manifold change over valve
- G39 Heated 02 sensor
I'm trying to KISS, but will be adding the bigger turbo & injectors along with an appropriate tune when I get it running.
Thanks in advance for any advice and suggestions.
- N79 PCV heating
