Ovrhill
- Joined
- Jul 9, 2019
- Location
- Haltom City, Texas
- TDI
- '04 Jetta Wagon BEW, '06 Golf BEW, '15 Golf TDI(sold), '05 Golf TDI (wrecked)
I have replaced the timing belt on my BEW wagon and the camshaft or torsion position seems to have changed with the new belt in place.
With the old belt on the torsion was just about zero. Now, with the new belt on, it is fully retarded to the point that the cam holding pin is difficult to remove. When the cam pin and the crank lock are removed the engine will spin without resistance. However, if I try set the torsion more to zero, I seem to meet some resistance when hand spinning at the crank. So, I guess I'm probably off a few teeth somehow.
I've done a few of these without issue. Just not sure where I might have gone wrong.
Anyway, should I remove the valve cover and make sure that the cam lobes are in the correct position with cylinder #1 all the way up? Or, is there an easier way to make sure that everything is lined up at TDC?
Thanks.
Thanks.
