CanadianALH
Where should I start with troubleshooting this? Where could I find specs for the voltage and resistance I should find at the switch? Or should I just swap the switch with the drivers one and see if it works? I also saw that there may be a relay under the seat as well that I could check. If anyone else has had this problem how did you solve it?
