valvecrusher
I bought a 'dead' passat. It was running, but advertised as 'needs engine rebuilt'.
I've had it since Dec.
I finally got VCDS and was checking the timing, it was 'too advanced to be displayed'
I set the timing on it, a '96 B4 1z passat, and while driving around in 1st...all of the sudden the engine (seemed) like it was going to run away on me, when i shifted to second...
then it recovered..
BUT!!
i noticed the timing on the VCDS went from 'slightly retarded, -- dead on!' to 'slightly advanced'...(exactly during this moment, cause my eyes were glued to the VCDS when it happened)
I was messing with the car for a few hours, and the timing didn't move from 'slightly retarded' for hours...
and after the semi-runaway(two, maybe three seconds)it was now in it's 'new' setting of slightly advanced...
2.
smoke is coming from oil fill cap, i guess that's head gasket, rings, or cracked head?
There are NO codes being set. BK ecu.
Is this the 'crank nose ruined' scenario? or i guess i mean, is this sounding like the 'c.n.r.' scenario?
so i mark the crank, and the sprocket, and then run the car a bit, and see if the timing changes again?
when it does, check the marks?
or
what else should i check for?
then it recovered..
BUT!!
2.
or
