Passat TDI coolant drain
s3npai
TX
2013 Passat SEL TDI
So I have a blocked heater core, and need to drain all of the coolant. Is the easiest way to do so to just open the hose on the bottom of the radiator and drain it there? I would figure there would still be some trapped in the engine if this were the case. Any ideas?
steves96tdi
Adamstown, Maryland
1996 Passat TDI 320k, 2015 Passat SEL TDI NOS w/140 mi., 2015 Passat SE TDI 6sp MT, 2014 Passat SE 6sp MT VW Buy Back
You might check this out:
Take the connections loose at the firewall, then blow air through one and push anything in the core back out the other. Then place a big towel on the floor inside so the few drops left in there get collected in something when you take the pipes loose.
s3npai
TX
2013 Passat SEL TDI
Heck yeah! Thanks! I had only ever opened the one on the lower rad itself and only got a cup or two out. Major disappointment.
s3npai
TX
2013 Passat SEL TDI
Genius. Is there a secret to getting the two lines apart at the heater core. I attempted this once before and could not get them seperated to save my life. I tried using a flat blade screwdriver, but got nervous because it looked like it was chewing up the aluminum lines.
