Passat strut replacement - need part #'s
Rick P.
Barrie, Ontario
'97 Passat, Tornado Red, RIP Feb 17, 2006
Passat strut replacement - need part #\'s
Anyone happen to know the part numbers for the front and rear strut bearings, boots (AKA protective sleeve) and the foam gasket Bentley says to replace at the rear? I've spent 30 minutes on the phone with the local dealer and the parts guy still can't figure out what I need.
Looks like what was supposed to be friday's job has been put off a week
Rick
dupp
Oxford, MS
Re: Passat strut replacement - need part #\'s
I would check Impex or Importec. I replaced mine @ 6 mos ago and bought the struts, mounts, rubber covers w/o any problem.
If I remember I'll bring the billing info tomorrow with pasrt #'s.
Mike
tomo366
TDI Lifer, Member #68
Kensington, Maryland USA
2015 Jetta SEL TDI
These are the Part #'s I bought this stuff from Impex
Tom,
Here are the other parts and numbers and prices from www.vwparts.com
333513425
BOOT
$8.77
$7.10
2
$14.20
333512131B
STOP PAD
$22.58
$18.27
2
$36.54
357512333C
RING
$6.35
$5.40
2
$10.80
357512183
GASKET
$2.00
$1.70
2
$3.40
357512335B
RING
$6.35
$5.40
2
$10.80
N90126602
WASHER
$2.57
$2.08
2
$4.16
357412303F
STOP
$17.01
$13.77
2
$27.54
357413175A
BELLOWS FRT
$13.65
$11.05
2
$22.10
1J0412249
Strut Mount Bearing
$8.55
$7.27
2
$14.54
357412331A
Strut Mounting
$35.59
$20.00
2
$40.00
96Wagon
Southern BC
96 Passat, 06 Golf
Tom.
You should get some kind of kickback from vwparts.com with all the Passat traffic you send there. I ordered the same info that you gave me, and had it within three days of ordering it.
Thanks again Tom.
Rick
