CleverUserName
- Joined
- Oct 25, 2014
- Location
- NorCal
- TDI
- 2014 OZ Cruze CTD & 2010 JSW 6MT & 2017 GMC Canyon CCLB ATX 2.8 Duramax
You may need to switch to a 17x7 wheel with 45-50mm offset your get them to fit. Eibach and 034 Motorsport make rear control arm kits with adjustable camber as well.Hi, it’s not a problem on the front. Only on the rear. But it seems it’s a common issue since 3C0505433K and 434 it’s more likely 8 mm wider on each side.
but i cant figure out what wheelspecs i will have to run. I have 2 sets. Original Talladega 19 8x19 et 51
And 7.5x18 et 47 both of them sticks out approximately 20mm on each side.
