Bohonk
New to TDI's but not new to mechanics..
So I have had this 05 Passat for a little bit now and its time to start digging into it.
It does have stage 2 tune from Malone, Egr delete, Maf delete, immo delete...
I am having an issue with its idle on cold starts. When I first start it up after its been sitting, it will idle ok, then start randomly "missing". Few times it will miss consistently for a few seconds then idle ok, then miss, then idle, etc... Its totally random, and only happens when cold. If its missing and you press the pedal, it goes away. Once its been idling for aa few minutes or you go drive it, it doesn't miss again until next cold start. The other note is that there is a fair amount of white smoke when cold. I know there is some oil in the system from a turbo going out but maybe its related..
Anyway.. I don't have VCDS, but I do have an autel that does quite a bit. Doing some reading leads me to believe its an injector issue so I have the injector quantity info
It is usually something like this when its missing (Forgot to grab exact numbers but this is close.
013-1 injection quantity cylinder one -1.49
013-2 injection quantity cylinder two 0.45
013-3 injection quantity cylinder three -2.99
013-4 injection quantity cylinder four -0.50
After a short time and it stops missing (2 minutes at 2 grand this time) the numbers went down to this
013-1 injection quantity cylinder one 0.33
013-2 injection quantity cylinder two -0.64
013-3 injection quantity cylinder three -0.21
013-4 injection quantity cylinder four 0.49
It runs great on the street and idles great when warm. This is only with a cold start and seems to be regardless of the outside temperature. Did it in the middle of summer, and now it's 30's and it does it the same.
Any directions would be great and I can get more info if needed while I have the scanner with me. I am just lost with all of the information and these diesels are new territory for me.
Thanks!
Thanks!
