Is the coming home/leaving home setting still turned on?... the headlights will no longer stay on a while after locking the car up and walking away nor when unlocking it as you approach.
It should have always been the full horn beep.Light switch is in auto and the feature is enabled in MFI. I don't get it...
What I also noticed since activating the rain sensor and rain close features is that my ATA Confirm horn beep when locking the car has become much louder. It used to be just a slight little chirp when stock that you wouldn't mind setting off late at night but now it's more like a full horn beep. Any ideas how to get that lesser horn beep back?
That is correct....Again, no big deal. I'm more concerned with the coming/leaving home feature. That is something I would like to get back.Which coding changes did you actually make? The way I read your earlier post, the Coming/Leaving Home just quit working without any coding changes being made by you.
That's correct - it is only a feature if the light sensor recognizes it's dark (same as if the headlights come on automatically). Let us know what you find...good luck!Good point. Mine did came with the alarm option and I know I once did get lost in the BCM module and might have inadvertently checked or unchecked something. I definitely miss the half horn chirp. Hopefully I'll figure it out someday.
Coming/Leaving home only works when it's dark out right? That may be my problem. Going to wait till it gets dark tonight to confirm.
Idr if it was mentioned or not. Has anyone found the code to keep the engine running after opening the door from remote start?
There has been some discussion that the gauge sweeping may not work on the Passat. I haven't tried it.if you miss your guage sweeping on the golfs etc, one can turn it on in these chinese clusters- i think??? by: go to 17- instruments- go to adaption- select indicator celebration
set to active and viola
just on a side note i really hope this isnt going to turn my kombii into a fancy looking brick as this could be for calibration maybe???
see it in action here :http://youtu.be/UtdVRucjL4s
it does work on mine however it only works on cluster h07-705; NOT h07-507, as 507 says channel not available, it therefore may only work on 2013 model year cars, BTW did ya like the video, did it myself:sorry for the Saudi meeper; i was just too lazy to switch it back to american yet as we are still 8.5 k from our next serviceThere has been some discussion that the gauge sweeping may not work on the Passat. I haven't tried it.
