Deezil_n_Dachs
Hey Jarrod, thanks for the info. Found it tonight and confirmed that the automatic setting works.
It won't affect your warranty work at all.i changed coding on instruments, central electronics, and rns+media player 3... hearing the turbo whine; anybody know what that will do to warranty work?
What does the rns+media player 3 change do? What change did you make?i changed coding on instruments, central electronics, and rns+media player 3... hearing the turbo whine; anybody know what that will do to warranty work?
Please note that this won't automatically correct for altitude! If you're way up in the mountains, you may need to fiddle with the xgauge calculation a bit to get it to display correctly. You want to shoot for 0-1 PSI at idle.TXD 07DF0170
RXF 054186700000
RXD 3810
MTH 00910BB8FF6F
edit: I just adjusted MTH to be 00910BB8FF54, which corresponds to 0.0 PSI with the engine off at my altitude.
It works fine on my mid-2010 MacBook Pro running VMware and windows 7My laptop is a MacBook Pro...I know Ross-Tech says you should use a computer running Windows natively and virtual PC's like Parallel might not work but has anyone ever tried it using VM Ware Fusion?
Same here, been doing it for 2 years. No issues. Currently VMware Fusion 5.03, on a 13 Retina MacBook. I have moved the VM between 2 different MacBooks when I upgraded.It works fine on my mid-2010 MacBook Pro running VMware and windows 7
go to instruments -long coding helper-select saudi arabia in byte 1 i believe from pulldown menu... will change radio to kick off only after driver door is opened after turning the car off... will also change chirpers and seatbelt warnings to different sounds...VCDS worked great with Fusion for me. Thanks!
My TDI has the the keyless ignition. When you turn the car off, it shuts everything down including the accessory power to the radio. Is there any coding that could make it so that if you get somewhere and want to shut the engine but you have to stay in the car you could just shut the engine but the power to the radio stays on? It works that way in many other cars with push button start and they just shut everything off when the driver's door opens, not just because you hit the starter button. That would be much more convenient and logical then having to hit the button again to start up the slow ass RNS 510.
It doesn't beep incessantly. It beeps once and you can suppress the main warning by pressing OK on the steering wheel.go to instruments -long coding helper-select saudi arabia in byte 1 i believe from pulldown menu... will change radio to kick off only after driver door is opened after turning the car off... will also change chirpers and seatbelt warnings to different sounds...
beware though that it will change mfi to throw up an orange color speedometer symbol and beep incessantly above 74 MPH
really? i didnt know ok turned it off THANKS vdub!It doesn't beep incessantly. It beeps once and you can suppress the main warning by pressing OK on the steering wheel.
However, it beeps every time you go above 74 mph, so it can get annoying if you speed up and slow down a lot.
You bet. Pressing OK will acknowledge any MFI warning and return you to the normal screen. The orange speed warning will still continue to cycle across the top of the MFI even after you press OK. It will alternate between that and the time/compass/gear.really? i didnt know ok turned it off THANKS vdub!
Stupid **** like what?sometimes I just wonder what the software engineers are thinking when they think of stupid **** like this.
+1 for American vehicles.
If you're talking about the Saudi Arabian speed warning, that's something that the Saudi gov't mandates for traffic safety.
Your car doesnt have auto headlights? My piddly SE does.Over there I can understand it. But we are in the us market. My main gripe is the mfd in general. It's pathetic. The read outs it gives is basic. I have driven enough newer diesel vehicles, some gas that provides way more info than what vw gives us.
The other thing of having watching this thread for awhile, it's sad that you have to use vcd to get some function that the car should have provided in the first place. Radio needs to say on after shutdown without having to have the stupid steering wheel light come on, and having to change the country the speedometer works under to get another function. Auto headlights have been a standard in American vehicles for years now. Why do you have to get a higher end car package to have that? It just appears to me that the engineers are just behind the times as usual.
Now the rest of the car is fine and generally up to date. It's just the electronics I have an issue with. I just like the engine mainly. Not a big dsg fan tho.
I don't follow... the MFI gives all sorts of useful information, from navigation aids to a very complete trip computer to various user preferences that are stored based on key so you and your significant other can have the car behave the way each of you prefers. What additional information would you like to see?
Auto headlights are standard on the Passat TDI - how is that a complaint?
Changing country code to unlock more options is an added bonus - show me another car on the market (besides Audi) that you can connect to with a $250 piece of computer software and edit the car's long coding to tailor it to your wants/needs.
Bottom line is that you get a lot of gadgets and functionality in a car that has a comparatively small price tag. If you want zillions of additional gadgets, I suggest looking at an Audi, Mercedes, BMW, or a Lexus - this is a Volkswagen.
If you go to Japan and drive over a certain speed (120KPH if I recall) you will hear an audible alarm, mandated by GOJ. And yes, this applys to Ferrari's, Lambo's and cars that can do 120 KPH in second gear.
again, should be standard in us version.Set the cluster to "Germany" to get the radio to stay on until the driver's door opens when you turn off the ignition and you don't get the speed warning you do with the "Saudi Arabia" cluster setting. Works on my SEL and others report it works for them.
