fairbanks
- Joined
- Mar 8, 2013
- Location
- Midlothian, Il.
- TDI
- ‘14 Passat TDI SEL ‘14 Jetta Sport Wagon ‘14 Passat TDI SEL
2014 VW Passat TDI
I just finished a water pump/ belt replacement. I bleed the injectors and attempted to start, I pressed Ignition button, Pressed brake pedal, pressed ignition button, what happens is the glow plug lights flash, and the car will not start? After 15 tries at this it started! Drove out of garage, topped off fluid, car at temperature, shut off. Went away for a few days, tried to start car, after may tries as described above car started, drove around block has power, sounds wonderful!
But now I am back to the glow plug light flashing which is off until I press the ignition, and not starting.
I have a VW Audi code reader, and it has a code 03189.
Anyone who can help, please.
Eric
Eric
