Changed the timing belt and the timing was advanced above the specified range. I retarded the timing a little by rotating the injection pump. Timing is now 65 and 100, in the middle of the advanced band. Then I checked the specified start of injection and actual start. Specified start should be between 2 and -3, but now it cycles between early and late. Actual start should be between 2 and -3, but it's between 3.7 and 7.9 When specified reads late, actual is 4.2 and when specified is early, actual is 7.7 Before the timing belt change specified inj start and actual start were within spec. My guess is I'm a tooth too advanced on the injection pump. Somehow I rotated it one tooth counterclockwise. Does that make sense? Remedy is to turn the inj pump sprocket on tooth clockwise and then reset the timing?
