Understood.
I scanned it but there are many codes so it doesn't help me. But i will put the scanned results if someone is willing to look through them and give any suggestions I'll be thankful for that.
Thursday,23,January,2025,10:36:56:02392
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: 1VWBV7A3XFC037699 License Plate:
Mileage: 252040km-156610mi Repair Order: 1/23/25 B
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 4F 52 56
62 72 75 77
VIN: 1VWBV7A3XFC037699 Mileage: 252040km-156610miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: Cannot be reached 1100
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CVCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 016 D HW: 04L 907 309 K
Component: R4 2.0l TDI X20 9466
Revision: 8AX20--- CVN: B12134C50000000000000000
Coding: 011D0012032410081000
Shop #: WSC 23116 035 00000
ASAM Dataset: EV_ECM20TDI01104L997016D 004002
ROD: EV_ECM20TDI01104L997016D.rod
VCID: 3436C3BEDEBBFA2A8B3-8060
VINID: 0669D2987443A164C00C71892489D6D6F1
No fault code found.
Readiness: 0 0 0 1 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 061 T HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4518
Revision: 05652104 Serial number: 00001407241428
Coding: 0000020
Shop #: WSC 09003 957 00200
VCID: 25102EFA69E193A20CD-8070
1 Fault Found:
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 252041 km
Time Indication: 0
Date: 2025.01.23.
Time: 18:27:28
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: C54BC0F549250001A31103ED92220042A1100012
VCID: 0456537ECE1B8AAA7B3-8050
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 42
Mileage: 251949 km
Time Indication: 0
Freeze Frame:
Count: 2
Count: 14
Count: 4096
Count: 16390
Count: 42496
Count: 0
Count: 768
Count: 0
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 251949 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 14
Count: 20480
Count: 16401
Count: 42496
Count: 0
Count: 768
Count: 0
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0343473827 Dataset Number: 560116v____ 0002
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 372CF4B2CFCD1132AE1-8062
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 561 907 426 E HW: 561 907 426 E
Component: AC Manuell H02 0303
Revision: 00001K02
Coding: 0010001002
ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
ROD: EV_ACManuaElectGen2BHTC_VW36.rod
VCID: 1D60061A4D315B6254D-8048
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0174
Revision: BL122001
Coding: EF200E1B802B2AD4098800010600854800F1A086448015B064806000AC70
Shop #: WSC 42399 001 1048576
VCID: 78AE378E82D3DE4A67B-802C
2 Faults Found:
00985 - Right Tail Light (M2)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 3
Reset counter: 46
Mileage: 251951 km
Time Indication: 0
Date: 2025.01.04.
Time: 18:28:08
Freeze Frame:
Term 15 On
Voltage: 14.10 V
ON
ON
OFF
OFF
OFF
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 2
Mileage: 251949 km
Time Indication: 0
Date: 2025.01.04.
Time: 00:36:34
Freeze Frame:
Term 15 On
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 AA HW: 5C0 959 655 AA
Component: AirbagVW10 500 0975
Serial number: 003LYD01EKH. Dataset Number: 560003v__A_ 0134
Coding: 00004D52
Shop #: WSC 00355 004 1048576
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 71B80AAAE1298F02A05-8024
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y1400018FFA0L
Coding: 303044
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME69080B47ZZZ
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME41655B47ZZZ.
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME40595B30ZZZQ
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME57345B30ZZZS
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME36460431ZZZL
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME7B4B0431ZZZ-
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 1K5 953 521 BR HW: 5K0 953 569 AH
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140625101406
Coding: 000A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EA22196A077E07A2D7-802A
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-YVJ H07 0023
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 G HW: 561 920 970 G
Component: KOMBI H04 0813
Serial number: 00000000000000
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 1E6201164037407A4D7-804A
2 Faults Found:
10485833 - Internal Control Module Memory Check Sum Error
B2000 49 [10001001] - Internal Electronic Failure
[Steuerger t defekt (SiWaLa)]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 225085 km
Date: 2023.09.22.
Time: 00:00:07
10485824 - Internal Control Module Memory Check Sum Error
B2000 41 [10001001] - General Checksum Failure
[Steuerger t defekt (EEPROM-Bereich Tachokennlinie)]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 01101403000658
Coding: 461000
VCID: 005E5F6EDA03968A5FB-8054
3 Faults Found:
01302 - Control Module for Telematic (J499)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 251949 km
Time Indication: 0
Date: 2025.01.04.
Time: 00:36:14
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 251949 km
Time Indication: 0
Date: 2025.01.04.
Time: 00:36:14
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 251949 km
Time Indication: 0
Date: 2025.01.04.
Time: 00:36:14
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0813
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
VCID: 6A8A1DC6CCFF7CDAE1F-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000208851005
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X_VW32.rod
VCID: 303ECFAE2AA3C60AEFB-8064
Address 2E: Media Player 3
Cannot be reached
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0008915953
Coding: 0404B5
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BE4480213A515526A9-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14202630140929233555
Coding: 800000
1 Fault Found:
131584 - Motor for Rear Window Regulator
B11EE 54 [00001000] - Missing Calibration / Basic Setting
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 44
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:10
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 215 3501
Revision: 00H22000
Shop #: WSC 01357 011 00200
VCID: 3928F28AF5590742585-806C
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 01030108
VCID: 6FBC0CD2F79D99F2B61-803A
Subsystem 1 - Part No SW: 561 959 591 A HW: 561 959 591 A
Component: J245 P05 9BA3 H08 0005
Serial number: 53388786011411902514
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0004
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0008921598
Coding: 0404B4
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CE64B1E16AB126A633-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14102631140930123210
Coding: 800000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 44
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:13
Address 56: Radio
Cannot be reached
Address 75: Telematics
Cannot be reached
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666552062 Dataset Number: 5N0035729E 0001
Coding: 0000000000000000
Shop #: WSC 36135 005 1048576
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 323AC5A624AFF41A99F-8066
7 Faults Found:
9455635 - Telephone Microphone
B1048 13 [00001001] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 2
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:15
9457427 - Left audio channel for speech/telephone
B104F 13 [00001001] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 4
Mileage: 251996 km
Date: 2025.01.19.
Time: 04:57:55
9457171 - Right audio channel for speech/telephone
B104E 13 [00001001] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 4
Mileage: 251996 km
Date: 2025.01.19.
Time: 04:57:55
9458195 - Control Module for Cellular Telephone
B1052 13 [00001001] - Open Circuit
[Bedieneinheit f r Handyvorbereitung (Drei Tasten Module): Unterbrechung]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 3
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:15
13636608 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 2
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:15
0022 - Radio
U1066 00 [00001001] - No Communication
[Steuerger t Radio (RNS): kein Signal/Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:15
0023 - Databus
U1121 00 [00001001] - Missing Message
[Telematik Einheit: keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 251949 km
Date: 2025.01.04.
Time: 00:36:15
End----------(Elapsed Time: 01:07, VBatt start/end: 12.4V/12.4V)-----------
