Passat B8 2016 2.0 BiTDI 240HP 4motion --> 16" rims possible?
Moggy1
Belgium
Passat B8 BiTDI
Hi all, anyone knows if a 16 inch rims will fit my Passat 2016 BiTDI ?
On all other Passat B8 type cars, 16/17/18/19 are factory listed.
Not so for the BiTDI.... Only 17-18-19 inch rims listed.
It might have something to do with the bigger disk brakes and it being 4x4 drivetrain?
In case anyone asks; I want to use them with high wall AT/HT tyres for off road driving.
Thanks in advance!
Peter
JELLOWSUBMARINE
yes
Love to see some pictures when your set
Moggy1
Belgium
Passat B8 BiTDI
sure, why not, but nothing special to be seen
i want the tires a bit bigger; something like 215/75-16 ,bit of a Jekill/Hyde monster
PS that is an immensely cute VW pickup you have there!!
NSTDI
Nova Scotia
13 Passat Sep 12
Check the gap between whatever rims you have now and the caliper. Look like room for a smaller rim?
Moggy1
Belgium
Passat B8 BiTDI
Hi, can't do; don't have the car yet... in 10 days time... In the mean time; I wanted to look for 16" rims - if they fit...
thundershorts
west chester pa
2015 passat tdi sel premium 2015 golf s tdi gls tdi b5.5, 2002 eurovan,Peugeot 505 td,Citroen cx25 prestige
Assuming 16's would fit, I would think the whole feel of driving the b8 would change in a negative way.
NSTDI
Nova Scotia
13 Passat Sep 12
Didn’t realize you were in Belgium, no B8’s around here. Judging by the size of the front caliper on our US made B7 only barely allowing room between the rim and caliper for my 16 inch Audi rim, if you say your B8 has larger than normal calipers, I’d say it’s a safe bet a 16 inch rim is not going to work. Maybe check images on google, you may find some with a caliper visible that shows the gap.
Moggy1
Belgium
Passat B8 BiTDI
It might change. What exactly is "negative"? Anyway, the 16" are meant for off roading where ground clearance and damping (higher tires) are more important than 200km/h cornering on a road/racetrack...
Moggy1
Belgium
Passat B8 BiTDI
It's tricky; a Passat B8 with 190HP engine can be factory ordered with 16" rims. My 240HP can not; (only 17",18",19")
I'll let everyone know once I have the car and borrow some 16" rims...
740GLE
NH
look up what rotors you have, if they are 312mm, most 16" should fit. if you have larger rotors of say the Golf R 340mm, then most 17" will work.
The extra sidewall always wins for ride comfort over looks and increased cost of rubber bands.
740GLE
NH
tdi club has a picture hoasting site, check out the header banner, it's a seporate login but same account/PW.
740GLE
NH
you gotta post an embeded link in the thread, then we'll be able to see them.
740GLE
NH
We have one now A6 Avant, just out of price range of what a normal person wants to spend when they can get a Cross over Tiguan/Atlas.
A proper Euro B7/8 Passat Wagon wouldn't be priced much different than an A6 with a long roof.
Moggy1
Belgium
Passat B8 BiTDI
Passat B8 BiTDI
in Europe in general, a Passat with these specs is around the price of a Audi A4 wagon -mind; without the 4x4...!
A6 is comparable to the Passat but a lot more expensive
price/value/resale/incredible inside space,... I believe the Passat is kind of unbeatable :love: -just my idea
pedroYUL
MI, USA
me, looking at those pics 🤤
Hey @Cuzoe , come have a look at those pics, brah
...so, Peter, your car has two sequential turbos if I recall correctly from something I read a long time ago. Do you know if it is a one larger unit, or two turbos truly sequential?
Also read that your engine should have a 2nd DEF injection further down the exhaust, does your car drink a lot of DEF?
740GLE
NH
NOx standards were a lot lower in the EU than US so I can't image it'd drink it any more than a US DEF system. If you're towing a 3,000kg camper i'm sure you'll notice it a little bit.
Remember Mk7 golfs TDI didnt have DEF systems.
740GLE
NH
Passat B8 BiTDI
Yeah but comparing a US spec A6 to a Euro A6, prices in euroland are higher. The contenting across the pond isn't a 1 to 1 conversion factor.
scrambld
Belchertown, MA
'06 Jetta...TDI/5spd :) >>>now a '15 Passat TDI/DSG
Appears to wear an R32/Passat 4-MO caliper (most likely with a 345mm rotor), so most likely looking at a 17" minimum.
