Hello, I have a Passat B6 2007 1.9 TDI BLS and the problem is it doesn't start very well when it's warm but starts great when it's cold (most of the time).
I scanned the car with VCDS and this is the only fault I got :
1 Fault Found:
000833 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal - Intermittent
I changed the camshaft position sensor and the problem is not fixed. I also changed: battery, starter, fuel pump, and crankshaft sensor.
Does someone know what could be the issue? All the mechanics/repair shops I visited see the Camshaft Position Sensor fault and tell me I need to replace it and the problem will be solved but looks like it's not the sensor.
1 Fault Found:
