sdcatdi
My 2005 B5.5 Passat with about 135K on the odometer recently began going into limp mode sporadically. Took it to my local independent mechanic and the saga of attempting to solve the problem began. Codes were scanned, vacuum system and fuel system issues were ruled out. The turbo was chemically cleaned. Drove away and within 30 miles had limp mode again.
Turbo was then removed and replaced. Picked up the car and within 50 miles limp mode returned. Back to the shop multiple times for trial-and-error recalibrations of the turbo (shop informed me the turbo came from the manufacturer mis-calibrated). Shop would test-drive the car, pronounce it fixed, then I'd drive away and limp mode would recur within a day or two, and we'd start again.
Finally the new turbo was replaced under warranty and the shop drove the car about 60 miles without issue. I picked up the car and within 100 miles intermittent limp mode returned.
While not always the case, the problem typically occurs when the engine is cold and/or when I'm going up a hill. I then pull off the road/freeway, restart the car, and things are fine until the problem recurs - sometimes within minutes, sometimes not for days.
I'm at the end of my rope and I think my mechanic is too. I've changed the fuel filter, air filter, fuel pump, turbo. I'm now over $2,500 into this problem and still experiencing the same issues that prompted the first visit.
Has anyone experienced this problem before? Any idea what the cause may be or what else can be done at this point to address it? I'd very much appreciate any guidance the group can provide on this. Thank you!
