AlanTDI
- Joined
- Apr 18, 2002
- TDI
- 1996 Passat wagonTDI, 02 jetta sedan, on the dark side 2017 Rav4
Hello,
Long story no so short.
2012 Sportswagon turned in Dec 7th
Put the 1996 Passat back on the road, after sitting in driveway 2 years.
Has front end fresh 4 years ago at M&M NJ, and alignment. Haven't driven it much since then only flushed brakes and changed oil, did the dreaded blend door last month.
Wanders to the left, while coasting. Already have new tires.
Mavis said alignment numbers were off, got alignment, no change.
Put on my garage lift, bushings, ball joints tie rods look and feel good.
On lift noticed, perished front motor mount(replaced 5 years ago with Meyele missing rear sub-frame bolt, missing lower start bolt, and loose upper starter bolt. leaking oil pan gasket.
My question is part numbers for
Rear sub-frame bolt
Lower starter bolt.
Is the rubber oil pan gasket a better choice than the cheaper Rein or Elring?
Also, does any one have these bolts they want to sell me?
Thank you for reading.
Rear sub-frame bolt
Lower starter bolt.
