passat 2.0 tdi CR
zed7862
West Midlands
Passat b6 2.0 CR
Hey guys,
was after some help. I recently had the engine light come on and after a scan it stated code:
P2196 02 sensor signal biased / stuck rich bank 1 sensor 1.
I have since replaced the 02 sensor on bank1, checked all the wiring. run diesel system cleaner through it and the light automatically went off but then returned 50 miles later it just doesn’t go away.
wandering if the turbo actuator may need replacing but not sure if that would cause this issue.
Really stuck here and could do with any help please.
Thank you
zed7862
West Midlands
Passat b6 2.0 CR
I have a basic bluetooth obd2 reader which i can use with my phone.
i have noticed when reading sensor data there is 0volt to 02S1
is that normal?
took a couple screenshots whilst driving 20mph. can anybody help interpret?
mextdi
San Antonio, TX
2006 Jetta TDI 1.9, 2012 Passat TDI SE DSG, Previous 2014 Beetle TDi, 2012 Golf TDi DSG
I was looking at normal sensor readings for an O2 sensor and it seems it reads .1 of a volt so maybe that is why the reading is so low.
After you replaced the sensor, what code is it giving you? The same one?
If you are worried about the turbo actuator, the zip tie fix is usually very easy to do and very easily undone as well, it is something to try. I haven't done the zip tie fix on a 2.0 CR, just on the 1.9 PD so you might have better luck on the MK6 forum here because the 2.0 CR is more common on those cars.
How many miles are on your car?
Cheers!
zed7862
West Midlands
Passat b6 2.0 CR
Hey Mextdi, I have just checked this against another passat and the readings seem to be just as kine are.
im not sure if it could be the actuator I was asking if that could be a possibility as i am not the most experienced with these cars.
123k on the clock mate.
zed7862
West Midlands
Passat b6 2.0 CR
Here is the dreeze frame data
Freeze frame
Freeze frame DTC P2196
Calculated Engine load value 0%
Engine coolant temperature 85 oc
Intake manifold absolute pressure 98 kPa
Engine RPM 1452 rpm
Vehicle speed 50 km/h
Intake air temperature 26 Oc
MAF air flow rate 22.99 g/sec
Throttle position 83%
Fuel rail press. 46870 kPa
