burn_your_money
**UPDATE** NO MORE PARTS ARE AVAILABLE AT THIS TIME
A phone number is required for international shipping. Please make sure to include that either in your shipping details in Paypal, or PM it to me to avoid shipping delays.
Can has around 550k kms (340k mi) on it. It ran well but was always in limp mode due to the 5th injector being disabled but not programmed out.
Parts are in North Bay, ON and I will ship. Please provide a Postal Code/Zipcode when asking for a quote.
Feel free to make offers. The more you buy, the less reasonable your offer has to be. Prices are in USD. Prices are just as a starting point. If you think my price is off, make an offer. I want to see this stuff moving.
Block: $50
Pump (probably leaks): $75
Alternator w/ clutched pulley: $30 bearings are a bit noisy, probably from sitting
Starter: $40
Air Box: $25
All boost pipes: $100
Turbo - 2 snapped bolts and the 3rd mounting hole does not have threads like it should. Zero in and out, very little side to side (like new basically) - $150
Intake manifold - $100
EGR pipe for non EGR cooler models - $40
Exhaust manifold - EGR studs need to be replaced - $75
Pedal assembly - $150
Engine wiring harness - $80
CTN transmission - missing some stuff from the tower -$100
Axles - $50 each
Driver's side reflector/marker light - $20
Interior pieces - Not much, make an offer
Mirrors - $30 each
Intake pipe from turbo to top of timing cover - $20
Timing belt outer cover - There is a crack - $25
Timing belt inner cover - $25
Turbo oil return line - looks like the braided section will need attention soon - $20
AC lines - $20 each
Anything else, just ask
PENDING
Roof trim things
SOLD
Head
Injection Pump Bracket
Injectors
Valve Cover
Headlights
Grill
Coolant flange with glow plugs
Oil filter housing with cooler
Vacuum pump
Downpipe
ECU
Cluster - I don't recall anything not working on it but it has been sitting for a year
Dash wiring
Injection lines
Click on the pictures for full res. Ask for any other pictures you need
Found a few more parts in the trunk
2x NEW parking brake cables - made in Poland - $40 for the pair
Set of rear shocks with springs - $60 for the set KYB GR-2 341124
Power steering pressure line
More pictures below, not sure why there is a 20 picture limit
Block: $50
Starter: $40
Air Box: $25
Axles - $50 each
Mirrors - $30 each
AC lines - $20 each
PENDING
Roof trim things
SOLD
Head
Injectors
Valve Cover
Headlights
Grill
Vacuum pump
Downpipe
ECU
Dash wiring
Injection lines
