Parting out 1996 Passat wagon B4V 1Z TDI
burn_your_money
Missouri
99 Beetle, 96 B4V, 05 Passat wagon
**UPDATE** NO MORE PARTS ARE AVAILABLE AT THIS TIME
A phone number is required for international shipping. Please make sure to include that either in your shipping details in Paypal, or PM it to me to avoid shipping delays.
Can has around 550k kms (340k mi) on it. It ran well but was always in limp mode due to the 5th injector being disabled but not programmed out.
Parts are in North Bay, ON and I will ship. Please provide a Postal Code/Zipcode when asking for a quote.
Feel free to make offers. The more you buy, the less reasonable your offer has to be. Prices are in USD. Prices are just as a starting point. If you think my price is off, make an offer. I want to see this stuff moving.
Block: $50
Pump (probably leaks): $75
Alternator w/ clutched pulley: $30 bearings are a bit noisy, probably from sitting
Starter: $40
Air Box: $25
All boost pipes: $100
Turbo - 2 snapped bolts and the 3rd mounting hole does not have threads like it should. Zero in and out, very little side to side (like new basically) - $150
Intake manifold - $100
EGR pipe for non EGR cooler models - $40
Exhaust manifold - EGR studs need to be replaced - $75
Pedal assembly - $150
Engine wiring harness - $80
CTN transmission - missing some stuff from the tower -$100
Axles - $50 each
Driver's side reflector/marker light - $20
Interior pieces - Not much, make an offer
Mirrors - $30 each
Intake pipe from turbo to top of timing cover - $20
Timing belt outer cover - There is a crack - $25
Timing belt inner cover - $25
Turbo oil return line - looks like the braided section will need attention soon - $20
AC lines - $20 each
Anything else, just ask
PENDING
Roof trim things
SOLD
Head
Injection Pump Bracket
Injectors
Valve Cover
Headlights
Grill
Coolant flange with glow plugs
Oil filter housing with cooler
Vacuum pump
Downpipe
ECU
Cluster - I don't recall anything not working on it but it has been sitting for a year
Dash wiring
Injection lines
Click on the pictures for full res. Ask for any other pictures you need
Found a few more parts in the trunk
2x NEW parking brake cables - made in Poland - $40 for the pair
Set of rear shocks with springs - $60 for the set KYB GR-2 341124
Power steering pressure line
More pictures below, not sure why there is a 20 picture limit
TDI Jim
Gaithersburg, Maryland
1996 Passat, 1996 Passat Variant (RIP), 2002 Jetta Wagon, 1995 Passat Variant TDI conversion brought back from the dead, 1997 Passat Variant project, and returned 2014 Passat
I will take the ECU, corner lamp, any inside front door black plastic triangles in good shape and especially the rear wiper washer cover for starters.
TDI Jim
My zip is 20882
burn_your_money
Missouri
@TDI Jim , the ECU and corner light are both pending, I should know tomorrow about them hopefully. I think I have a few sets of the interior triangles. How many do you want? Is the rear wiper washer cover on the interior or exterior?
TDI Jim
I need at least 2 sets of interior triangles, and let me know about the ECU and corner lights. The rear wiper washer cover is on the outside.
TDIDaveNH
Left Lane Coal Roller at Large
North Conway, NH
1997 Passat TDI x2 1984 Buick Century 4.3 diesel. 2012 X5d 2012 Passat 6-speed
Im interested in the PS pressure line and both fuel lines from the tank to the filter shipped to 03860. I’ll PM you my phone number, thanks.
carl h
Ocala, Florida
2014 VW Touareg TDI White 2013 VW Touareg TDI White 1996 B4V white. 1996 B4V Blue. 2005 VW TDI Station Wagon Gray. 2015 VW TDI White
By chance do you have a couple of inside door trim pieces?? I can send you the pictures of the parts I need.
burn_your_money
Missouri
My apologies to those waiting on me to pull parts and get a shipping quote. I hope to get the parts removed by the weekend, assuming the weather cooperates.
Poor King
NY
'91 Jetta, '91 GTI, '04 Touareg
I didn't see a price for the front motor mount bracket, rear transmission bracket and the rear motor mount. I would like to have all those when you remove the motor. PM sent.
Bob S.
Central MD.
A B4V, some ALHs & BRMs
No worries. When ever is good for you. Please attend to your more pressing matters first.
Poor King
NY
Might as well take the front crossmember and the bracket for the brake booster- called it 🤓
Nebuu
the twin cities
97 passat tdi
Interested in both front corner lights, both headlights, grill, front bumper, headliner, sun roof cover, possible drivers window motor/pieces.
I'll have to look tomorrow what else I may be interested in. Let me know what's still around, shoot me a pm when you see this I'm horrible at seeing forum replies
carl h
Ocala, Florida
Wanted to say thank you for the inside trim parts, and as you might expect I had another request, super small item,
it is the small light when you open tailgate in the B4V
Thank you for your consideration.
Regards,
Carl
