Parting an 02 Jetta - Massachusetts
sweetjeep
North Central, MA
2002 Jetta
Hey folks. I helped prove recently that, in fact, 2 objects cannot occupy the same space at the same time. Thanks Einstein. Jerk.
So.. I'll be parting out my Jetta..
The body has 245k. It was a front end accident so some parts are available.. some aren't.
1) No egregiously high offers will be refused.
2) The motor and REQUIRED parts are not for sale. But see rule #1.
3) I will base all shipping as though you are in area code 90210.
4) Feel free to ask if I have a part. I am not going to list everything on the car.
Here are the highlights:
I got my hands on a 2002 GTI VR6 when this car had 180k on it and the GTI had 77k. I swapped over the following parts:
Trans output hubs.
Axles
Front brake assemblies. So if you buy the calipers you'll get the mounting hardware too.
Rotors are available separately. I have 2 sets. The current set is from EBC, as are the pads. Red Stuff pads. The current rotors might have a tiny lip as they are about 20k miles old. The other set of rotors has a ton of meat left but they do need to be turned as they are rusty as hell from sitting around.
Struts are Bilstein TC (black body) with the GTI Vr6 springs, I can get you the color code if you need. Shocks have approximately 40k on them
Shocks bilstein TC also. Put on at the same time.
Rear springs are also from the same GTI.
If you want the airbags, they didn't deploy. Imagine my delight as the seat belt allowed me to hit the steering wheel! :) I don't blame the bags. The car was previously hit and I suspect a shady repair.
The driver side headlight is an e-code. The passenger side is "assorted roadside debris".
The car was otherwise full power, and everything worked so if you want switches or something.
Interior is black upper/gray lower. Gray headliner, black carpet. Seats are GTI leather but are spoken for.
4 spoke steering wheel with controls, and as mentioned a non-blown airbag.
rear bumper has a small hole in it because I couldn't be bothered to move a trailer one day.
I have a couple sets of wheels. the VR6 GTI alloys. They have studded snows on them. And a set of flat black (spray paint) Wolfsburg wheels with about 30k on the tires. I am up in the air on selling the wheels just yet as there is a tiny chance there is another dub in the works.
Trans is a 5 speed but it is likely spoken for.
On the motor: In the event that someone wants to make me a crazy offer that I can't possibly refuse. It has 245k on it. I checked the cylinder pressures at 200k looking for an oil leak. Low pressure was 390, high was 410. The oil leak was the turbo. So the current turbo is a 17/22, 3 bar, and using a Kerma Q-loader and tunes to support it. Injectors are the Kerma DLC 1019s. I think they are 1019s.. I can double check. With an 11mm pump and was 100% rebuilt by DFIC (because the kid who sold me the pump was a scumbag liar, but that's a different story). Timing belt is 40k old.
As I said, I am not inclined to sell the motor, but if someone wants to offer me a silly amount of money for it and it's related bits and pieces, I do need to buy a new car. ;)
The car is silver and the body is all good minus the hood, front bumper and passenger fender.
The quality of the interior is "pretty good".
I can send pictures of whatever you may car to have a look at.
csstevej
north nj
2001 golf tdi 4 door auto now a manual, mine, 2000 golf 2 door M/T son's,daughters 98 NB non-TDI 2.0, 2003 TDI NB for next daughter, head repaired and on road,glutton for punishment got another tdi 2001NB,another yellow tdi NB , added an 06 NB DSG
Eudaemonic
Boston, MA
'02 Black TDI Golf
Is the downpipe considered to be in the 'required engine parts' category? Is it in good shape? I'm in Boston and could pick it up this weekend.
Thanks!
sweetjeep
North Central, MA
2002 Jetta
Eudaemonic: Nope, not a required part. I ASSUME it's in perfectly fine condition. But I'll take a look see and shoot you a PM.
Lug_Nut
Sterling, MA. USA
2015 GSW 6M in S trim the other oil burners: 1967 two stroke Sonett 1988 Bolens DGT1700
Always looking for small 'gingerbread' items. Current list is:
side mirror glass, either or both, if heaters work
rear ashtray clamshell
front ashtray holder (the part around the red ashtray insert)
Steering wheel, if the cover isn't crumbling and no teeth are embedded
front pass airbag cover
Engine top cover
Battery front cover
Battery top cover
Jetta headlight bulb access covers, one high and one left low
Will consider the studded snows
If you need to ship to CA and then back to central MA let me know in advance,
Or I could extract these bits and pieces this weekend to save you the time and effort.
PM or e-mail will work.
sweetjeep
North Central, MA
2002 Jetta
Lugnut: In your case, I am 100% confident I can deliver for free. Or at least meet you somewhere if you don't care to come to the junkyard I call a home. I'm in Templeton. I'd bet solid money we pass each other commuting rather often.
As to your parts list.
Side glass.. good and heaters work - but to be confident they didn't die I'll put an thermometer on them.
Ash tray pieces are good to go.
Steering wheel does NOT have any teeth in it and isn't crumbling. It's getting worn in the common spots, but I think a little leather dye would solve that problem if you are worried.
Pass airbag cover is also good to go. I'll ASSUME that it is removeable? Or is it the whole dash? I have never looked.
I think I have the engine cover. I took it off about 200k ago. ;)
I doubt I have either battery cover. I know I have broken them repeatedly on every VW I have ever touched.
The passenger headlight parts, I may be able to help out, but you'll have to be more specific. The passenger side is mostly on Rt2 in Acton and some in shopvac. But I have a spare set of headlights that may have what you need.
The snows have a season or 2 left on them. I'll get you a picture. It's really the wheels that are of value there. Though I planned to run the snows this year and somewhat expected to run them next year too.
csstevej
north nj
Lug_Nut
Sterling, MA. USA
More items about which to inquire:
Lower intercooler hose (to fit between stock plastic pankake pipe and my VNT17's hose adapter)
front rotors
Engine top cover
Battery front cover
Battery top cover
Call. I have Sunday free.
<edit> Sunday's come and gone <end>
sweetjeep
North Central, MA
2002 Jetta
Lug_nut.. I don't have your # ! :)
I will check on the lower hose. It may be good.. may not be. The intercooler was dislodged from it's mounts and the upper hose was smashed. On the rotors. I have 2 sets, and they are from a Vr6 GTI. I MAY have a set of stock rotors floating around too.
Lug_Nut
Sterling, MA. USA
Won't the time and shipping costs from MA to CA make the used light assembly more than a locally sourced used one?
kiva822
Chico, CA
'03 Wagon
flat rate shipping is pretty cheap USPS and we have no local source. Our wrecking yards (all 2 of them) only have mk3's...
