Part replacement questions on '96 TDI Passat
Rapidrob
Edgewood,New Mexico
96' Passat Wagon
I'm getting ready for a 4,000 mile trip. And I need to do some part replacement due to age/ minor leaks.
1. The T-stat is now stuck open and needs to be replaced. What temp in F do I need to get? 180 or 195F?
2. Should I replace the T-stat housing inlet pipe as well? What is it really called?
3. The water pump is weeping at the front seal. Which brand do you recommend?
4. The harmonic balancer just started to squeal when cold. I see them from 80 bucks to several hundred. Which one to buy?
5. I've always used VW OEM coolant. Is there an aftermarket just as good?
Thank you for your imput.
Mozambiquer
Versailles Missouri
I'd get what's available from idparts. Get the oem parts, they are a lot better quality. When was the timing belt last replaced?
South of Boston
Definitely get a new coolant flange. They warp with age and often break when you remove them.
prsa01
mpls,mn usa
14 jsw 6m, 96 B4v, miss my a4 :(
Every once in awhile I forget how incredibly helpful some/most folks on this board are. It is SO nice to get these little pearls of wisdom from the folks who know so much about these cars and their parts.
Thanks IBW and the others on here for spending the time to help us all out. It is VERY much appreciated by those of us with more a willingmess to try than actual knowledge!
Abacus
That helpful B4 guy
Only the B4V left
It doesn't matter. I have run both and saw no difference either way. Diesels like to run hotter but the 195 thermostat made no difference in the other wagon compared to the 180 in my B4. I have not had good luck with Wahler but have had good luck with the Napa 238. The Wahlers seem do die early and I have not replaced a Napa thermostat twice. They could be made by the same company for all I know.
Yes, as Peter mentioned, they tend to warp. I have found the non-OEM VW ones tend to warp and distort whereas the OEM VW ones do not, but they often require replacing the o-ring which has gone though heat cycles and lost its elasticity. IDParts or Cascade German are reputable places to get them and both are top notch. I get 90% of my stuff through them but haven't had to buy much lately since the car doesn't see as much use.
I had two Graf metal impeller water pumps die on me early (<10k miles) so I am not a fan. They use stamped metal impellers whereas the Hepu or Geba used a different metal impeller that was more robust. I have a picture somewhere but cannot find it right now. The stamped one on the Graf heated up, expanded, and slipped on the shaft, causing the car to overheat, but this was 10 years ago. I have installed Graf pumps after that and they were fine but I never fully trusted them. Definitely get the metal water pump gasket, it saves time works well, and is easy to just strip off when doing the next one.
The one I have is Valeo, and I think it's made in Italy. Not sure if they're still available since I've had mine for years. I have installed Chinese ones and they never seem to last so I try and avoid Chinese parts when I can.
Pentosin SF is available at Napa and a direct replacement, but it can cost as much as the OEM coolant. It comes as a concentrate in a quart that you dilute.
