eb2143
I somehow managed to damage the parking brake cable rubber boot when I was installing the cable about two years ago. The boot I'm referring to is ribbed, about 2'' long, present at the caliper end of the cable, and prevents water (corrosion) and grit from getting to the area of the cable that must slide in and out of its sheath.
I knew the boot was important, and managed to snag one used off the forum (AFAIK you cannot buy them individually--I'd love if someone proved me wrong), but then could not get the boot over the large metal ball at the end of the cable without ripping my replacement boot.
So long story short, I don't have the boot installed on the LR and just tried to dab some thick grease on it.
Went to a car wash yesterday and fairly quickly realized the caliper in question (LR) was sticking, presumably d/t ice.
So my question is: Has anybody devised a work around to keeping moisture/grit out without having to buy and install another cable? I was thinking of trying heat-shrink tubing?
Also going to get these: http://forums.tdiclub.com/showthread.php?t=364603
TIA
TIA
