GTOguy
I see that Diesel Geek doesn't list one for our beetles and I don't see a way to email them on their site, probable have to set up an account. Dose anyone know anyone that makes a comparable product?
UFB. Thanks for the info.Pump, FYI the ECS tuning plate will not fit a Beetle with out modifications. It probably fits the Jetta just fine. I got mine to fit but I had to take the rear bend from -6 to +3 and grind a little clearance for the air deflectors that go from the fender to the inner wheel well liner. Then use a 1/4" spacer (supplied) in the center location at the rear and use 7/16" spacers on each side. I was able to use the supplied bolts. With these mods it fits and looks good. I would have had to use 1" spacers and the wheel well liners would have not reached the plate if I had not redone the bend.
