Yamasaki
I'm pretty sure that my panoramic sunroof is not in the fully closed position and needs to be adjusted. This is on a '12 Sportwagen. .
The front edge of the sunroof does not sit flush with the roof.
When fully closed, I would estimate that it sits 1-2mm too low and 1-2mm open. See the below pic for the best image I was able to capture:
I have wind noise and I most certainly have leaks (The drains are being cleaned and in some cases replaced).
I believe I could eliminate most of the drain issues if I could eliminate the water ingress in the first place.
The sunroof appears to operate just fine. It opens fully and the tilt feature works. It also closes fine, just not 100%.
Anyone know how to adjust this roof? Dealer tells me it looks fine but something is not right here.
