****Part 1****
This is my first try at a write-up but hopefully it serves well as these cars gain more miles and I suspect this problem becomes more common. My car is a 09 Jetta TDI with 90,XXX miles on it currently. I am getting a CEL with code P2015 Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance Bank 1/ VAG
From what I’ve gathered through my research of the intake manifold, there are two intake valves per cylinder (fill channel and swirl channel) making 8 intake valves total with half of them being covered by the intake manifold flaps. The 4 intake valves without the flaps provide constant air to the engine while the 4 flaps open at a higher RPM to give optimum air movement to the engine. (Refer to pages 7-9 on manual or 11-13 on PDF viewer) http://www.dsd.go.th/itrain/km/kboc...Diesel_Engine_2.0L_TDI_CommonRail_BIN5_UL.pdf
That being said, I have had this code on my engine for a little loner than I would like (2-3 months) but have gathered that it’s not something that needs fixed immediately but like any problem it still needs fixed before it causes more trupble. I have read you should not expect lowered MPG but cannot 100% confirm this as I do mostly city driving and only get around 32 MPG anyways. Although the few times that I have gotten my car onto the highway for (longer) drives I did see a few MPG less that expected.
Troubleshooting Procedures:
***Use only gold-plated terminals when servicing any component with gold-plated electrical harness connector terminals.***
* Disconnect the Intake Flap Motor (V157) electrical harness connector.
Checking voltage
• Switch the ignition On.
* Using a multimeter, measure voltage supply between connector terminals 1 to 3 for voltage. Refer to Wiring Diagrams for Pin locations.
Specified value: approx. 5 V.
* Using a multimeter, measure voltage supply between connector terminals 4 to 5 for voltage.
Specified value: near 4.35 V.
* Using a multimeter, measure voltage supply between connector terminals 2 to 3 for voltage.
Specified value: approx. 5.01 V.
* Switch the ignition Off.
If the specified value was not obtained:
* Check the wiring for a short circuit to each other, Battery positive, Ground or high resistance.
* Check the wiring connections for damage, corrosion, loose or broken terminals.
* If necessary, repair the faulty wiring connection.
If no malfunction is detected in the wiring and the voltage readings were correct:
• Replace the Intake Flap Motor (V157). Refer to the service information for removal and installation procedures.
If no malfunction is detected in the wiring and the voltage readings were Not correct:
Checking wiring
* Remove the Engine Control Module (ECM) (J623). Refer to the repair information.
* Using a multimeter, check the Intake Flap Motor (V157) electrical harness connector to the Engine Control Module (ECM) (J623) electrical harness T60 connector for resistance. Refer to Wiring Diagrams for Pin locations.
Specified value: 1.5 ohms Max.
If the specification was not obtained:
* Check the electrical harness connector for damage, corrosion, loose or broken terminals.
* Replace the Engine Control Module (ECM) (J623). Refer to the service information for removal and installation procedures.
Final procedures
After the repair work, the following work steps must be performed in the following sequence:
1. Check the DTC memory. Refer to => [ Diagnostic Mode 03 - Read DTC Memory ] See: Computers and Control Systems\Testing and Inspection\Scan Tool Testing and Procedures\Diagnostic Modes 01 - 09.
2. If necessary, erase the DTC memory. Refer to => [ Diagnostic Mode 04 - Erase DTC Memory ] See: Computers and Control Systems\Testing and Inspection\Scan Tool Testing and Procedures\Diagnostic Modes 01 - 09.
3. If the DTC memory was erased, generate readiness code. Refer to => [ Readiness Code ] See: Computers and Control Systems\Testing and Inspection\Monitors, Trips, Drive Cycles and Readiness Codes.
Checking voltage
Checking wiring
Final procedures
