P2015 never gone PASSAT CC 2009 CBAB TDI
Badry
France
Passat cc 2009 TDI CBAB
Hello,
I have 3 months with this code P2015 :mad: :mad: :mad: but till now No solution yet!?
My car was normal till i changed the EGR valve to new original part. After 2 weeks the check engine light ON.
With VCDS testing only one code is P2015.
So i Changed all this parts to new Genuine VW parts= 🤑🤑🤑
*Intake Manifold 03L129711E
*V157 Flap Motor VDO Continental A2C59506246 AIR INTAKE MANIFOLD FLAP ACTUATOR MOTOR
*3 DIESELGEEK (3 parts from internet)
After all this still have the code P2015.
What i do ? i have testing the Flap motor Voltage with VCDS gaves me (1.280V minimum and 3.890V in maximum) this case when the flap motor is plugged on with the intake manifold that is not normal.
When i taking off the flap motor and do a test with VCDS in that case gaves me (0.456V and 4.100V) that seems normal for me.
but when i put it on the intake manifold gaves le the old results (1.280V minimum and 3.890V in maximum) it's really strange for me ?
Really i do not know what to do ?
please guys if you can give advises
thank you
Regards
