P2015 - Intake Manifold Flap Position Sensor (Bank 1) - TSB
aum110
USA
2005 Jetta
Hey guys,
I am having an issue where the P2015 (Intake Manifold Flap Position Sensor (Bank 1)) code keeps coming up, and I can't figure out what is causing the issue.
When I look at the Ross-Tech website (http://wiki.ross-tech.com/wiki/index.php/18447/P2015/008213) it says:
"When found in a VW Golf/Jetta (1K): 1.9l PD-TDI (BRM), check Engine Control Module (ECM) Software Version:
  • 03G-906-016-AB @ 7328 or 7550 as well as 03G-906-016-AC @ 7280 or 7551 do have a Software Error which requires a special Adaptation for the Intake Manifold Flap Motor (V157) which at this Point can only be performed with the Factory Tool."
I checked and I have that version of the software.
Does anyone know if there is a TSB that discusses the need to have the software updated? I looked all over and can't find anything.
Any suggestion on how to get the dealer to update the software?
crashtested
Nelson, BC
2014 GSW Trendline 6MT, 2004 Jetta GLS 5MT (sold), 2010 GSW Highline 6MT (buy back)
Check here :)
