2010 Golf TDI P2015
Hey guys,
I work at a shop and we had a customer with a 2010 Golf TDI come in with a flashing glow plug light as well as a CEL, we scanned the car and it had two engine codes:008200/P2008 intake manifold flap;bank 1-electrical malfunction
and 001592/P0638 throttle body actuator bank 1(j338)-implausible signal
we did not stumble on the diesel geek fix at that point so we checked the wiring and ended up replacing the intake flap motor, customer picked up the vehicle it ran good for half the day and started having the same issues: rough idle and hesitation when accelerating. We later got the bracket in, installed it, had the same issues so I got him to come back in to check the bracket to make sure it was flush and pull up the intake flap in vag com. I adjusted the bracket slightly since it wasn't completely flush. The codes which were in the system before clearing them were: P2015(was in the scan twice), P2006, and P2004. When clearing the codes, the P2004 (intake manifold flap stuck open) code stayed on and did not clear. when in basic settings, the lower voltage stops at 1.292V the higher limit of the voltage stopped at 3.648V.
After adjusting the bracket the customer called back saying that the vehicle was running great but he had scanned it a found a p2015 code in the system.
Any ideas would be greatly appreciated
Thanks,
Phillip
