2010 Jetta TDI with ECU Emissions Update. DPF Changed at approximately 80k mi. Car currently has about 145k mi.
I was able to clear P1A58 when I ran Regen while Standing. Just in case anyone runs into the same issue, to start the Regen while Standing in basic settings (after entering the security code in), you have to click the on/off/next button and then press the brakes 10 times before hitting the accelerator peddle (even though it says accelerator peddle after pressing the brakes once). I figured I'll put that out in case anyone else had the same issue. Regen temp was 606c and 546c.
