P1007 P0300 P0304 resolved
jrock
Dallas, TX
Jetta, 2001, Blue, Passat, 2012 Silver
VAG Code: P1007 P0300 P0304
Symptom: Low power, stumbling and hesitation until engine starts warming up.
Resolution: Replaced all 4 injectors
Results: I now have a new Passat TDI :)
mak474
St. Louis, MO, USA
2013 Passat TDI SE
I had all 4 injectors replaced under warranty at the dealer due to this.
Yep, yet another of the growing number of CKRA-only ailments. Sometimes you can reset the injector values and lessen or fix the issue, sometimes you can't. I guess the solenoid type units just are not as robust as the piezo units the CBEA/CJAA use.
Fortunately I have not seen any engine damage occur from this, so that's a good thing. Because diesel injectors can be bad to the point they can blow torch a hole through a piston fairly quickly.
jjblbi
lbi, nj
2014 Passat SEL TDI
Just curious what do CKRA injectors cost? I remember BRMs were $250ish!!
BlackPiston26
Maryland, USA
2013 Passat tdi se
I just started getting this code (P1007) about 3 weeks ago. Haven’t had a chance to get to the dealer yet. They keep fighting me on calling Vw for warranty. I’m only at 95k miles
