dingleflopper13
Hello,
I have a 2011 Q7 andI recently deleted EGR, DPF, adblue, and swirl flaps. It was tuned out to reflect that before the delete because it was immobile prior to to faults.
After the delete while test driving it to take my garbage and recycling to the center it popped up the code above for cylinder 2 pressure too high and every other cylinder aside from 3 is currently saying contribution/balance.
It starts and idles seemingly fine and even drives somewhat normally unless trying to accelerate more than grandma would that causes hesitation and stutters. Drove it back home and shut it back off.
I used an Autel scanner and checked live data. Cylinder 2 is the only one even showing pressure data and it does seem to get high. Fuel pressure according to Autel seems to match actual versus requested pressure.
Could it still be the HPFP even with the pressures matching? Or is there something else it could be?
No other tuning aside from delete file has been done so no extra boost or any thing like fueling or timing.
