cesar011
Got a 2005 Passat wagon tdi 2.0 i am getting a p0118 engine coolant temperature high circuit. p0741 torque converter lock up solenoid stuck and p2108 throttle actuator control performance. car runs perfect shifts good. temperature at normal all times. throttle response is great. i have tried replacing the throttle body. the ect (engine coolant temperature sensor) the atf and filter. i even ended up replacing the pcm and same problem. fuses are good. anyone ever had anything similar
