Had this error code, cleaned the IAT/MAF sensor but error still came back. I ordered new Sensor and replaced the old one but still getting the same errors.
Does any one know what kind of resistance and voltage i am supposed to get on the pins at the connector of IAT/MAF?. Or can someone tell me the pin numbers/color on the ECU so i can try tracing the the wires?
Or if you can suggest key words to google i would also apreciate that.
Thank you for your help in advanced
5282 - Intake Air Temp. Sensor (G42)
P0113 00 [172] - Signal too High
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 254
Mileage: 210472 km
Date: 2021.01.02
Time: 23:09:53
Engine RPM: 1718.00 /min
Normed load value: 74.1 %
Vehicle speed: 56 km/h
Coolant temperature: 57 °C
Intake air temperature: -40 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.040 V
Unlearning counter according OBD: 40
Exhaust gas temperature sensor 4: 182.3 °C
Specified value of low pressure exhaust flap: 32.79 %
Actual value of low pressure exhaust flap: 30.70 %
Low-pressure exhaust flap: offset closed: 0.50 %
Low-pressure exhaust flap: status-Bits 0-7: 0
Low-pressure exhaust flap: status-Bits 0-7: 55
Low-pressure exhaust flap: status-Bits 0-7: 8
Low-pressure exhaust flap: status-Bits 0-7: 66
Exhaust flap: actual value: 1788.6 mV
Freeze Frame:
Fault Priority: 2
Mileage: 210472 km
Date: 2021.01.02
Time: 23:09:53
