update,
The new thermo switch arrived today and put it in, topped off coolant, evaced the air out of the cooing system, then test drove. Traveled up hill about 4-5 miles and temp started to rise, pulled off to put the heat gun on the radiator and low and behold the fans were running on high speed. Drove up hill another few miles and them temp started to climb once again checked under the hood and fans back on high. (came on appx. 220F) then (shut down at appx. 220F FYI). Felt both the radiator hoses and the top was hot and the lower was cold. The flow issues was apparent, had my tools and to rule out further expense, I pulled the new t-stat (aftermarket) out and ran with out it the rest of the way up the hill. It never went above 190 degrees F. I read that another guy posted that he had the same issue and it only resolved after he installed an OEM. Also, as Eddie made mention to change the temp switch sensor with a new one, which I did with after MKT, and they both failed, and the new OEM is what I put in today and the fans run! Well time will tell on the rest of the possibilities/issues. Thanks to all that chimed in!
