Hi there.
I just performed oil change on my 2013 Passat, using the fluid extractor I bought from Amazon. So I did not Jack the car, and did not mess with the drain plug.
I changed the filter and O rings before putting new oil. Also added some oil into oil housing before inserting the filter.
I extracted around 4.5-4.6 L according to not very clear measure reading in extractor container.
I filled the engine 4 L first and then ran for a while checked the level( very hard for me to read it because no min or max letter) and I thought should take close to 4.5/ anyway.
I added about 4.6-4.7L.
Resetted the service info.
Now, if I overfilled it maybe 0.1L or 0.2L would it be a huge problem?
Should I extract little bit and just let it be 4.4 or 4.5 L?
I will add pictures of dipstick. I know it should be in crossed area, but I could not get a clear reading after checking it several times.
What do you guys think?
I used mobil1 507.00 spec oil.
I'm also aware that this extractor is not taking %100 of the fluid. I will probably do the oil change from bottom every 20.000 miles to clean up?
https://i.imgur.com/MicgZ6s.jpg
