pyromancer
General car info:
2001 ALH Jetta
1019 injectors
Garrett VNT-17
3 bar MAP
Malone stage 4 tune
Vacuum at idle:
@n75 - 28.5
@n75 to turbo -19
no leaks I can find
IP:
6.0 - 6.2, just retested in VCDs 32768.
Hammer modded to between 5 and 7 per instructions with 1019 injectors from DBW LLC.
I am having an issue with the car slightly over boosting and then under boosting. To me it feels like there is a bit of a flat spot at low RPMs as well which is my major issue. I have had this issue since getting the tune in 2019 and it seems that Owain at Malone agrees, this should not be how the car behaves.
Original graph.
Mike at Malone suggested shortening the actuator rod to fix the lag I was feeling. Working with Owain I one turn at a time shortened the rod quite a bit. I would guess 6ish turns. Yellow on the rod is where the Lock Nut was when we shortened it, and where the Lock Nut is in this photo is it set to coming off the stop screw at around 19ish of vacuum after I set it back.
With the rod shortened to the yellow my graph looked like this.
Shortened rod
I developed a boost leak in the line to my boost gauge at that point and had to replace my 30psi boost gauge, as it wont read lower than 2 now =(
After fixing those issue, I couldn't find any other boost leaks. On seeing the above log Owain told me I am flat lining the MAF and getting the turbo to respond quicker will limit boost spikes, without giving me an explanation of what that means, or what if anything else I should try. I assume flat lining means I was spiking above the MAFs ability to read? If anyone has a better explanation would love to know.
I've been trying to troubleshoot on my own as well and reading what I can, this in particular seems to have good explanations on turbo control for an ALH, https://www.uk-mkivs.net/threads/vnt-tdi-turbo-how-to-adjust-actuator-cure-boost-problems.34834/ From what I can generally understand from reading up on stuff, the rational of making the rod shorter to the point we did has not made any sense to me at all. I keep reading things telling me shorter rod = bigger spike on a MK4. Owain keeps telling me getting the turbo to respond quicker will limit the boost spikes, but I don't understand... Like that should have happened if I was a small bit off and should have happened when we shortened the first couple turns, not taken like 6 turns right? Every time I have raised a flag, or asked about the adjustment, if I should check anything else, he has told me to go shorter on the rod, or not given me anything better than a confusing one sentence answer, but shortening that rod has only had the spike get worse and has not made the dip go away. What am I missing? I feel like I am just not understanding something or comunication has broken down, so am desperately searching for answers. We have been corresponding about this about once a weekish, or when he gets back to me, for a month now. I feel like shortening the rod is not the answer here, will only cause more problems, maybe cause more/worse damage, and there has to be something else wrong, but I don't know what else to try.
I reset the rod to having the actuator start to move at 19ish, graphed looked like first one in this post again. Then to make sure we weren't having bad communication on directions to move the rod to begin with I went longer instead to see what happened.
Longer rod
From my understanding of how the car works and the turbo control system, the above graphs would lead me to believe I have a boost leak. I always fall to about 2400mbar regardless of rod position. I have pressure tested from the turbo inlet to the EGR a few times now and can NOT find a leak at all though. Vacuum all seems good and I have no leaks there as well. N75 has been swapped for a new unit, behavior remains the same. Arm on the turbo seems to move freely when I removed it from the actuator arm. Turbo actuator holds vacuum and seems fine. I need help or ideas and am at my wits end trying to figure this out. I am terrified that if I shorten the rod again I am going to blow the turbo. The only things I can think of to try next would be: to clean the turbo(sticking vanes?), replace exhaust gaskets and nuts between the engine and the turbo (on the off chance I have an exhaust leak there?) and/or to pull the intake and replace all my gaskets for it as well (leaking boost from there maybe?). If anyone has other suggestions or some insight on what could be causing this I would love some help and input. Or even confirmation the above cleaning turbo and replacing gaskets would be my next best troubleshooting steps. I am at a lost for understanding this.
Any ideas? Again would love some help, please and thanks!
2001 ALH Jetta
1019 injectors
Garrett VNT-17
3 bar MAP
Malone stage 4 tune
Vacuum at idle:
@n75 - 28.5
@n75 to turbo -19
no leaks I can find
IP:
Original graph.
Shortened rod
Longer rod
