MJHandy and the rest of you tuning in.
As with anything, there is a quite a bit of science between mortar and bricks.
The key with bricks and mortar is that the mortar has to be softer then the brick. If you repoint an old house with portland cement/mortar, you risk ruining the brick faces after a period of time as the older bricks rely on the soft mortar for them to expand and contrast.
I found one contact in all of ontario,
thanks to a large limestone production facility. I'll be heading out to the GTA tomorrow in the afternoon to pickup 2 bags of Type S Hydrated Lime.
To properly fix a wall, it's best to tear down the old brick and mortar and install more updated stone and portland cement.
Here is an interesting link:
http://easementsatlanta.org/2014/07...n-csi-lintels-and-masonry-mortar-part-2-of-3/
http://easementsatlanta.org/wordpress/wp-content/uploads/2014/07/Nspall2.jpg
"Example of improper repointing and surface grouting with portland cement causing historic brick spall due to different compressive strengths."
So with all that being said and done, to do a proper job you need the proper stuff for the brick to look good, weather properly and move as it needs to.
If you need your chimney done, as do I, they need to take down a few feet of brick and replace it with newer bricks. With that being done, portland cement is fine to use.
If they are just repointing your old brick with portland cement...it's a quick repair that you will need to redo in a few years time.
